Cobra03
- 0
- 6
- Imperial, MO
how old is too old?
I messed with the injection pump today. It will not lose speed going up hill now. I found out I have a bad transfer case leak and axle pinion leaks. I have done a bunch of searching, but have not found the part numbers for them. Can someone lead me in the right direction? Does Napa carry stuff like this?
You can but they will rub significantly on the bed when the rear suspension articulates. You would need to limit suspension travel or raise the bed. Not a problem if you stay on roads, thoughCan I put a 16.00 20 on my truck?
I don't buy from civilian places unless it can't be had in surplus so I can't help you with NAPA. They wouldn't be able to do anything with the NSN but might be able to use the part number. Some military parts won't cross to civilian parts though.Swamp Donkey-- I saw those part numbers, but where can I get the parts? Can I give my guys at NAPA those numbers and they cross reference? Or do I have to get them from a mil surplus guy?
I did the same and ended up stopping a couple of leaks. I also just removed the shift lock solenoid on my T-case and cured my leaky front output shaft seal, along with another issue. If your building pressure in either the axles or T-case then new seals might not fix the problem.My pinion seal leaks completely stopped as soon as I ditched the spring loaded check valve vents and vented the axles to atmospheric pressure, ran tubes up high.
