1951M1078
- 185
- 63
- Glendale,AZ
Will, is that OK with DOT ?
If so I would do that .
Hey 1951, Congratulations on getting your truck on the road!First impressions of driving the M1078...Idle seams high? Needed to be firm on the brakes...May have been a little light on the throttle , would hang a little before shifting...Braking needs a lot of pressure...Had to be hard on the brakes...Is the idle something that I can set?...Its cool here 50-60. Motor came up to 200 +- and just sat their. (no fan)...Oil pressure at 200 deg. was 70 at idle...So do you need to be on the brakes firm at a stop? I saw ,in the mirror some wheel spin in revers backing into the shop ? (dirt) Don't think that is right. This was no throttle and firm on the brakes in revers....
NAPA sells dot approved splices ...Huston ! We have brakes !
Would like to kill the guy that cut the valve out of the system. I have just enough 3/8" tubing to test the system. But not enough to install the valve back into the mounting hole. BASTARD !
Install a new 1/2" hose but the 3/8" run to the rear. I don't think its legal to splice the runs to the rear ? So I will get to replace 50' of hose ! BASTARDS !
