Identifying cut wires under dash - M1165A1 REV
GMVguy
33
Texas
Looking at the under-dash wiring and trying to plan for the repair of the cut wires in the below pic. Can you identify which ones are cut?
NDT
6,532
Camp Wood/LC, TX
Sorry nope there are plenty more cut wires. Won't be too hard to figure out, these trucks are not too complicated. You will have wiring not included in any diagrams, that being the compressor and the IR light circuit specific to GMVs.
GMVguy
33
Texas
Thanks. This is not the GMV truck I referenced in other posts - this is the 1165 REV. I appreciate the encouragement - will trace em down!
PS - assuming the part number for the turn signal switch (6220-01-408-7785) is the same for all Gens, M998, 11xx series trucks, all through the REVs?
Mogman
9,594
Papalote, TX
Looks like four or five bundles... Best of luck, and hopefully no electrical components fried during the cutting when wires shorted out. :cry:
Missed one, he will have to remove the plastic loom to see what is going on there.
As far as I have ever seen the factory did not use plastic loom so it is likely part of the GMV upgrade.Cut.jpg
SCSG-G4
PSVB 3003
3,379
Lexington, South Carolina
Look for wire numbers near the ends. All military vehicles and trailers use the same wire number for the same function. Somewhere in the past, the full table of wire numbers was posted on this site. Hopefully a copy of that table is in the TM Library section.
SCSG-G4
PSVB 3003
3,379
Here is the common wire numbers.
Unfortunately he will not have the numbers where it will help the most, as Commo said allot of tracing wires.
GMVguy do you have a good schematic for that rig?
If not give me the serial number.
Thanks, I knew they were on the site, but could not remember where. One of the 'advantages' of old age.
