You can get it a CA plate. If I can do it for an '86 M936A2 you can do it for that. It took me awhile and I got told NO a lot just don't give up. Whether or not to pay weight fees in CA is another story I went historic. On the bright side I drove my wrecker across 8 states bringing it home and then another few thousand miles in CA and nobody stopped me even once. Without plates, too (in MI you don't have to put the plates on the vehicle because it detracts from the historic look that's where it was registered and titled). So don't worry.....
Get a laptop, download all the TM's, start reading. Bring the laptop with you. Get the axle sockets and the gear to change a tire (torque multiplier for lug nuts, air over hydraulic 20 ton bottle jack). Bring that as well.
I also retrieved a historic plated '68 M817 locally and drove it off a windy mountain road about 40 miles to my place. It's in pretty poor shape. I would offer that you make sure things work in more or less the following order:
-Brakes, brakes, brakes!!! Bleed them, adjust them, give them love. Pull the hubs and look if you have to. Leave nothing to question! This may take a couple days, some jacks and tools and maybe a small tractor to help.
-Tires. Get in there and really look at them. Older NDT's they put on these seem to get sidewall cracks. When in doubt swap them out!
-All the filters. Because.
-Do a valve and injector lash adjustment. It's probably been too long if you don't know. Show up with rocker cover gaskets and tools for that.
-Fuel system inspection. The NHC250 is real sensitive to air leaks. Even the little priming pump in the cab can goof it up.
-Axle fluids. All the fluids.....
All I can think of. The rest of the truck can be fixed with bubble gum and bailing wire (or maybe a local farmers buzzbox) just like Uncle designed them. If it's going to throw a rod unexpectedly then that's what it'll do. Sometimes there's no telling that part of the adventure. Most of the time you get fair warning.
Ton of work for sure. Great trucks though. Nice and simple. Still have a lot to do to my M817 but I dig it. Oh and hearing protection as well. Muffs AND plugs for that much exposure.
I've had a good time retrieving these. I think the previous owner of my M817 retrieved it from Texas in the winter. Great adventures, memories for a lifetime. Best of luck with it and safe travels!
