In need of a new air horn solenoid valve.
ida34
33
Dexter, MI
The title says it all. I put an want ad in the ad section. If no one has one I will order it from Saturn on Friday. I need the horn working reliably for the Memorial Day Parade.
Chuck
cranetruck
75
Meadows of Dan, Virginia
I started looking or one also some time ago, let me know if you find a source for it, low cost wise. :)
Meanwhile, I took mine apart and found the coil burnt up. I may rewind it and seal it back up with casting epoxy.
It takes about 280 turns, using 26 Gauge enameled wire if anybody is interested (1/4 lb spool).
BTW, this is for the 8x8, my deuce horn is a okay.
73m819
319
gainesville, ga.
i brought a compleat new horn, selenoid and all off ebay for about 15, used my old selenoid on a 152 db horn that i had
FreightTrain
Banned
2,730
13
Gadsden,Al
Make that one more.I found out why mine doesn't work.The Piston fell out when I removed the horn to do the turbo install(Have a International semi horn under the hood) and although I found the piston the spring is long gone.Plus the horn didn't work all the time so might as well replace it.I want to know the horn works if I hit the brakes one day and find out there ain't none!
808pants
Honolulu, HI
I'm three years late to this party, and maybe that's why I can't figure out who the mysterious "Joseph" is, or where he apparently posted that he had solenoid valves for sale (umm...was there a post # 3-1/2?), or where to contact him to see if he's still got one kicking around! Anyone?
--Dave
808pants
Honolulu, HI
Thanks, Bjorn...jeez...didn't know that could be DONE - gone without a trace, not even a 'this post has been deleted by its author?' That could be really confusing in a long thread.
--Dave
