Akicita
- 3
- 0
- Eastern Pennsylvania
My in-tank fuel pump is not working. A 20 (twenty) Amp fuse blew!! I need help from someone who understands electrics better than I do.
I followed the procedure described on page 2-219 in TM 9-2320-361-20 but need help interpreting the results.
I removed plug 654 from the socket on the tank top plate and read the following from the three terminals on the plate:
With the truck not running and the accessory switch OFF:
-31 VDC + 0 VDC + 0 VDC
With the truck not running and the accessory switch ON:
-55 VDC + -55 VDC + -55VDC
There were slight differences but I rounded all readings off to -55 VDC.
Then I checked the plug I had removed and read
0 VDC + 90-something + 90-something VDC
The meter kept climbing. I stopped when it had surpassed 90 VDC.
Why don’t I get a reading in the neighborhood of 24 VDC ?
What does a negative reading (minus sign in front) mean ?
I have not changed anything on the batteries since I bought this truck a year and a half ago, and it runs fine even with that pump inoperable but it takes longer and longer to get it started.
