85SmokinDetroit
- 18
- 8
- Pennsylvania
I put throttle shaft seals in my ip after studding my heads putting new 6.5 injectors in the 6.2 & new head gaskets to bolt on my holset hx40 turbo, I got the entire truck back together.
Bleed the fuel system and it fired right up for about 2 minutes idle perfect and then shit off as if I was sitting inside the cab and turned the key off, and wouldn’t restart until I cracked the injectors lines (bumping around in the ol power barn) & then got them back on and it restarted and repeated, idled perfect and then shut off like I hit the key I ordered a new fuel shut off solenoid
After testing it and it clicked but not a very thuddy sound like
I thought it was just kind of a small tap tap like it’s hardly moving hoping It solves the issue. any help or insight would be appreciated. Ps it has fuel at the ip but only little dribbles truck ran and drove fine before I was tinkering with it.
