Jestertac
- 0
- 1
- Tacoma, WA
My local hydraulic shop can't seem to get the proper (T) fittings and 90 elbows to replace the injector drip line hardware. They told me the fittings were 7/16 x 24 and they don't carry any for DOT airline. I took some of them off to get the proper sizing and crushed them in the process--so cannot reuse them. From looking at the pictures in the sticky, I think they were mistaken on their measurements, but They are closed until Monday so I was hoping for an off the top of the head correction. The online picture shows the hole in the top of the injector as 1/8th inch so I don't know why they can't get me another T fitting that the male DOT airline fittings will screw in to. If I have to, I can go back to the stock line by using the HD flare listed in the sticky, but I saw another thread where the OP stated most of his flares were badly sized. I would prefer to use DOT airline since the rest is done that way and also avoid getting a bad batch of flare fittings.
Any help would be really appreciated, I've spent hours searching the forums and online. Unfortunately I can't find part numbers or specifications to duplicate some of the work I have seen.
Thanks a billion guys. I'm looking for the injector pump oil lines and fitting also if you happen to know what those specs are. I could use crimped hydraulic lines or JIC if available for the oil lines.
