Andydieselpower
- 3
- 18
- Owatonna, MN
Still in the process of checking and adjusting all of the brakes on the M812. One of the brake drums was covered in oil which we found to be a bar inner oil seal upon taking it apart. Is there any trick to installing this seal into the brake drum? It keeps wanting to pop out. I bought a 6" piece of PVC pipe that fits perfectly on the outer rim of the seal so I could give it even pressure but this doesn't work. Any tricks? The tech manual is kind of vague on the install. The manual makes it sound like you put the seal on the spindle then slide the drum on after but I don't see how this would work? I'll try to get some pictures.
Thanks,
Andy
Thanks,
Andy
