Interesting discovery.
palmettopredator
Lowcountry, SC
So my 1028 decided not to start this morning. I am getting a click when I turn the key. So I read through the site to find a starting point to fix my big baby. I chose to start at the starter relay, but when I looked under the dash there isn't one! I don't even see the wires that attach to it. Any ideas? Kinda need to get it going or my significant other is going to put it on the chopping block. :cry:
The previous owner had already wired in a manual glow plug switch so the plugs are cycling but no start, just a click when I turn the key. I am getting 24v to the starter with the key turned so I think my starter might have gone.
Warthog
231
OKC, OK
Are you sure you are looking in the right place? The stock relay is located under the dash behing the STE/ICE connector plug under the ashtray.
There should also be two square relays for the GEN2 and Voltmeter
Warthog
231
OKC, OK
They should be part of the same wiring harness. The PO may have cut it out and jumpered the wires.
Warthog
231
OKC, OK
Start with the starter relay upgrade (dohead relay) but I'm thinking its time for a starter rebuild. If you upgrade to the newer gear reduction starter, make sure you get the correct support bracket.
