Swabadger
- 0
- 1
- Lake Mills, WI
Hi, I have a 1985 M1009 that has just recently started to have the brake warning light come on intermittently while driving on the highway. It does not come on while applying the brakes, and will be on for a minute or two, then go out.
The braking action is good, with no sinking pedal or need to pump brakes. No obvious signs of any fluid leaking anywhere and the master cylinder is not showing low fluid, and the fluid looks to be in good shape. It was converted to DOT 3 at some point (not by me) which I confirmed by mixing samples from the master cylinder with water and with DOT 5.
I haven’t bleed the brakes yet, as the light would make sense to me if there were air in the system and the light came on while actually applying the brakes.
The brake warning light does not come on when I apply the emergency brake. The wire is connected, but the light does not come even if I push the E brake to the floor.
Has anyone seen this before?
