Is there a cable for VIC-1 to PRC-77?
tennmogger
555
Greenback, TN
Is there a cable to connect the VIC-1 intercom to a PRC-77 or other radios with 'new series' U-228 type connectors?
I'd like to connect the VIC-1 in my Unimog radio truck to a PRC-174 HF radio and to a PRC-77.
Maybe I'll have to fabricate a cable but would prefer an original, if ever made.
Thanks,
Bob
tennmogger
555
Greenback, TN
Apparently there is no such cable.
Another related question: Any knowledge of the VIC-1 being used with any newer radio with the new series (U-229 type) plugs?
thanks
Bob
Boatcarpenter
Marlborough, NH
One possibility?
When the PRC-25 or PRC-77 is installed on the AM-2060 Audio Amplifier/Power Supply which is on the MT-1029 Mount the combination can be connected to the VIC-1 system just like if an RT-524 or RT-246 was on the MT-1029 Mount. The AM-2060 handles the interface to the VIC-1 system and the radio can also be used in retransmissin systems. For non vehicle mounted PRC-25 or PRC-77 retransmission systems the Mk-456 Retrans Kit is used.
Sorry for the blue, it was already blue where I copied it from.
Credit to PRC-68, Brooke Clark, for the information.
BC
tennmogger
555
Greenback, TN
Good info, Thanks!
Looks like I need to make a special cable because my setup does not have the AM-2060, MT-1029, or either of those radios LOL. But the MK-456 retrans kit looks interesting.
The mount in use here is the MT-3823/GRC, and has no extra connectors so no direct connection to the VIC-1 was intended.
(PS- I like blue)
tnx agn
Bob
ke6rwj
creating havoc one broken bolt at a time...
277
146
Alabama
its possible (really its just audio and a key circuit), but your biggest issue / concern will be to isolate the PRC77 from the VIC1 24 volt circuits. you will need to use the same circuit described here..
http://www.steelsoldiers.com/m37/68328-vic-1-m37.html
Im designing it to integrate with any radio... I have a couple PRC77, i think what i would do is to design a cable to interface this directly to the Audio Accessory Port on the PRC, then anything with the same military connection will interface...
The AM-2060 turns the PRC77 into a vehicle radion in the same mount as the RT524, so i would expect that to work...
this is an interesting idea...
