sailor2000
- 2
- 0
- Houston Texas
This is on ebay as a Deuce clutch... is that really all the friction surfacethere is on a Duce clutch????
Huh???M543A2 said:. Once we get the trucks rolling, we shift without the clutch most of the time anyway.
Up shifting without the clutch is easy once you do it a few times, but shifting down is harder to learn. You have to match the speed of the trans and the speed of the engine exactly for it to work. Just don't ever force the shifter. That will cause damage. I've shifted without the clutch regularly in all of the 4 speed and 5 speed vehicles I've owned. I had to learn to do it when my f-150 developed a leaky slave cylinder. I had to start it in gear a couple times and shifted without the clutch to preserve what little hydraulic pressure there was in the thing...sailor2000 said:Huh???M543A2 said:. Once we get the trucks rolling, we shift without the clutch most of the time anyway.
m-35tom said:is this all the friction there is?? this is a heck of a lot more than an organic disk, all that pressure is focused on 5 small spots. learn to engage clutch without slipping it and you will be fine.
