I should have mentioned earlier, but everything when smooth. The lights even worked (brake lights). The only thing I couldn't figure out was how the brakes worked. I hooked up the lines and activated the brakes to get it hooked up. It was pushing it back until I did that. Then when I got ready to leave, the trailer was locked down tight until I cut off the red light's valve and let the air leak off. I am not sure I had brakes on the trailer for the ride home.
Anyway, lots of possibilities with this set up. I do not plan to keep and maintain a road tractor so I am thinking if I was to move it around I should set the box on a bumper pull trailer so it would be easy to move with a cargo truck. Only time will tell.
