3rdmdqm
- 112
- 43
- Woodbine Maryland
Am I the only one that can't figure out how to attach the Jerry Can strap? I have seen some unbolt the can bracket bottom plate and run a single stap underneath. The one I got was a two piece. One of the pieces was already sewn in a loop but the only way to secure it to the slot/hole would be to run a dowel or something trough it wider than the slot to keep it from pulling through. I cut the stitching, fed it through and then riveted it in place. I wound up attaching the strap using 1/8" diameter aluminum rivets with 1/8" backing plates. We'll see how long they last. I then covered the ends with super glue to prevent fraying. Is there an easier way I missed?
