Brian46
- 0
- 0
- Langley BC
I am trying to figure out what was missing from the air system in my M931A2, the truck came from GL with an air leak when you applied the brakes, upon further inspection it appears a part was robbed from it and was causing the leak. A plug was put in place and the system works fine, but I think it was a sensor or switch that is missing and would like to confirm exactly what I need before just buying parts.
Here are a few pics, the fitting that required a plug (green plug in picture) is on the inside of the drivers side frame right next to the rear output of the transfercase. there are two loose wires there as well, that is what makes me think it was a switch of some kind that is missing.
Any help in identifying the part I need, or if you have one/know where to buy would be much appreciated.
Thanks
Brian
Thanks
Brian
