aceofspd
- 0
- 0
- Rochester/mi
First I want to give thanks for this great site. I have been lurking for some time wanting to buy a diesel generator for my home.
So I bid on this generator, bidding more than I should have and thinking it wa closer to me. Hoping to be out bid, I was high bidder by less than the minimum increase. The point being that with service charge, tax, and shipping, I might have a very expensive piece of scrap.
Ok, at first look it looks Ok for it's age. Pulled starter rope, not sized as others have reported. Fuel tank is a mess. removed and assembled it. Fuel filler all gummed up and torn . Inside cleaned enough to give starting a try.
Oil looked new, air filter looks clean, surface rust on the fly wheel cover, gauges yellowish, 47 hours.
Hit compression release and gave it a pull. Sounded like it tried to start. Second pull and it started and quit. Fuel not on and throttle not in start position. Restarted, plugged in a 5hp shop vac. IT MAKES POWER, how cool.
Point of interest, there is NO starter on this unite. Guess I do not have to worry about getting a pair of batteries and wiring a start switch and charger. Even though it is hard to pull the rope with any velocity, this baby wants to start.
What I need to know is where to get an "in tank" fuel filler and /or a complete Tank?
How does that float level switch Work? Has anyone made a manual override Switch?
Electrical question, since I do not need 240 in an emergency, can I hook a single 120 volt output to both legs at the same Time? This will eliminate trying to create a balanced load and no modifications to the genny.
Thank again for this great site.
Greg
Greg
