No, I belive it is multilift, from UK.tcody said:M1075,
Is that a Palfinger hook loader? What model? Would love to see a few more pictures of it!
Thane
Depends on what year it was built. The XT engines were great. The older 444's were a bit on the un reliable side. If it is CPL 806 or an early 910, watch out. They eat cams, break lower follower shafts, bend and break injector push tubes, soot the oil heavily, smoke white and run rough on cold starts and wear bearings prematurely. There were some changes to the later 910 and 1210 CPL engines that fixed the issues that were common on the 806 engines, turning the lower follower shafts 90 degrees...they broke at the oil holes, 17 to 18 degree injector cups to stop the sooting and bearing wear..might be the other way around on the cups..CRS kickin' in, the addition of a viscosity sensor and a check valve in the oil side of the injector to eliminate the heavy white smoke and rough running at cold start. There was also a change in the overhead set procedure from the top stop type of set to a torque method.Angus1 said:I can tell you that the cummis 444 and 444XT were great motors. But Injectors were very expensive. And be sure to run the overhead every 100,000 miles. I like it and wish I could get my hands on one.
Then I shall rephrase. I had a 444 and a 444xt in a pair of petes I owned, And only had injector issues with them.WillWagner said:Depends on what year it was built. The XT engines were great. The older 444's were a bit on the un reliable side. If it is CPL 806 or an early 910, watch out. They eat cams, break lower follower shafts, bend and break injector push tubes, soot the oil heavily, smoke white and run rough on cold starts and wear bearings prematurely. There were some changes to the later 910 and 1210 CPL engines that fixed the issues that were common on the 806 engines, turning the lower follower shafts 90 degrees...they broke at the oil holes, 17 to 18 degree injector cups to stop the sooting and bearing wear..might be the other way around on the cups..CRS kickin' in, the addition of a viscosity sensor and a check valve in the oil side of the injector to eliminate the heavy white smoke and rough running at cold start. There was also a change in the overhead set procedure from the top stop type of set to a torque method.Angus1 said:I can tell you that the cummis 444 and 444XT were great motors. But Injectors were very expensive. And be sure to run the overhead every 100,000 miles. I like it and wish I could get my hands on one.
M1075, that is a great truck, I have always loved T800 KW's. Does it run? The exterior looks to be in awsome condition. How's the inside?
Merlin-I have some info on the T800-PLS 8X8. I worked at Kenworth Division during the development & testing of these trucks. Originally (50) C500 PLS's were built for US Army (for evaluation?). I believe these ended up with Canadian Forces after testing. I have a friend who worked on the T800 PLS project and discussed this truck with him today. Here's what we remember. I was a party of KW engineers who spent time at FT. Sill, OK. where engineers were able to discuss what the motor pool mechanics and truck operators liked/disliked about the new Oshgosh HEMMT's being put in service at that time. We were able to ride with the operators in their field testing area. This input was used in the design and development of the T800 8X8 PLS. Two prototypes plus (10) trucks were produced for the US Army testing. My friend remembers 46,000 mi durability testing at Aberdeen Proving Grounds and some testing and exercises at Ft. Hood. He thought one went to Yuma as well. There was one rollover during tests at Aberdeen which was attributed to operator error. The trucks finished first in Army testing and the contract was awarded to Kenworth for 5000 units (as we recall). Production was planned in the old Pacific Car and Foundry site in Renton, WA. behind the (then new) Renton Kenworth plant. But the buy quanitities dropped to 1500. At that time, Paccar wanted to move the production to the Renton truck plant and run them down the commercial line because of the high costs to renovate the Foundry building for the smaller quantity of trucks. The Goverment would not allow these trucks to be built on the commericial line in fear of not being able to separate the costs of these trucks from the others (due to the cost plus contract). In the end, Paccar withdrew because of this, and the contract was re-awarded to Oshgosh the second place finisher.
These trucks were designed to kneel down for aircraft transportability. I did have an original sales flyer sheet on this truck but recently donated it to the American Truck Historical Society here in Kansas City. I was told that the tandem axle configuration of the HEMMT was prone to overloading wher the T800 tridem axle resolved this issue. I hope this helps.
