hdmax
- 5
- 0
- new Lexington, Ohio
At just 134 HP the truck should be an older 3/4 ton, or 1 ton crew cab long bed as the weigh much less than the newer one, so the lack of power would not be as noticeable. However if a pickup chassis is used you would probably need to go with a 4x2 or use a double stacked frame to allow room for the oil pan, even with a 4x2 there may not be enough room above the front end cross members. I would think that a 1 ton crew cab long bed pickup with 4.10:1 axle ratio, and a 5 speed overdrive manual transmission with 33" tires should get 22-26 MPG, but mileage shouldn't be an issue if running free or near free fuel.
It would be way cool to have a pickup truck that ran on used motor oil.
