LDT question
sinister
Santa Fe
This is probably a stupid question, but am I correct in thinking the multi-fuel engines have no glow plugs? If that's true, how do they start as good as they do considering they have no source of pre-heat, save for a manifold heater if equipped. Sorry for the "newbie" question, but it will settle an argument I'm having with a friend.
ida34
33
Dexter, MI
All the military engines had either a preheater manifold heater or either injection. They are only used when the temp gets below 20 degrees Fahrenheit. The engines start without glow plugs because the very high compression creates more heat than the typical light truck diesel. The LDT's have a very high compression compared to other engines. I think the LDT is around 22 to 1 with light truck diesels down around 15 to 1.
ida34
33
Dexter, MI
Re: RE: LDT question
goldneagle said:
Actually mine has a glow plug setup for real cold weather starting.
The glow plug set up must be aftermarket and it should not be needed until it gets well below freezing. The cucvs need glow plugs to start even when it is 70 F or so.
sinister
Santa Fe
That's what I was gonna say. my bubba's cucv M1008 has to use glow plugs. I never knew there was that much of a difference in comp ratios between light trucks and med-heavy duty stuff. Thanks for the insight.
cranetruck
75
Meadows of Dan, Virginia
You are probably looking at the intake manifold heater igniter (spark plug)....
With good batteries, your MF should start without aids down to about 10°F.
There are other cold start engines, like the Lister engine, which has an adjustable compression ratio, very high up to 40:1 or so, for starting and then 15:1 for running.
Got to appreciate the Multifuel. :)
goldneagle
1,014
Slidell, LA
RE: Re: RE: LDT question
Sorry my mistake. I thought the manifold heater igniter was a glow plug. So much for my knowledge of Deuce engines... :oops:
1,808
Aren't glow plugs generally used on indirect injection engines?
m-35tom
223
eldersburg maryland
right kenny, the multi is a direct injection engine and these do not use glow plugs. engines with glow plugs have prechambers that the glow plug and injector are in and are usually more noisey engines having fuel knock.
Opie
Salem, VA
I learn something daily here. I'd wondered about this question for a while...
mangus580
282
Western NY
Actually, the 6.2 is like 22.5 to 1, and I think Chevy's 6.5 is in the same range. Alot of the guys 'hopping up' their 6.5 will drop the compression to 18 to 1, to be able to achieve higher boost pressures safely. Incidentally, they start harder in the cold when that is done!
2,758
Re: RE: Re: RE: LDT question
cranetruck said:
Four decades later....
And I'm STILL amazed that it can burn gas w/o killing it'self!
jimk
45
Syracuse, New York
The minimum temp. needed for diesel compression ignition is about 700*C(1300*F). Very cold engines can lose that heat to the cylinder walls, piston crown and chamber. If the loss is high enough the threshold may not be reached. If it isn't the engine cannot start. Aids include glow plugs, ether, block heaters. Each is a different way to solve the problem.
Old engines have a hard time because rings and valves leak . That reduces the actual compression. Batteries have less output at low temp. Engine internal friction is high because the oil is thick. That causes slower cranking speeds. This allows even more time for compression leakage. JimK
