Leak at Injector
CGarbee
569
Raleigh, NC
While preping my '83 M35A2C for the Veterans' Day parade this past weekend, I noticed that I have a drip comming off my number two injector at the fitting on the plastic line that ties it to the number three injector... I put a wrench on it and tightened the fitting a tad and it slowed the leak down to a slow drip, but I was afraid to honk on it too hard considering that I need to be running the truck on a weekly basis through Christmas...
I suspect that this has been covered before, but what is the best source for new line and fittings? I'd like to have spares on hand before I get more aggressive with the line wrench, and I sorta suspect that the line is old enough that it should be replaced anyway...
Thanks.
cranetruck
92
Meadows of Dan, Virginia
Those are the return lines. I have some extra nylon tubing I can send you. You can reuse the fittings, but you will need new ferrules.
PM a mailing addy and I send you the tubing.
