Miah
- 29
- 18
- Kansas City-ish, MO
Evening folks.
So my Filter base appears to be leaking...but it doesn't appear to be the typical middle sensor.
My leak appears to be the lowest sensor that bolts to the back of the base & runs through it into a port at the bottom of the filter. Filter is only a couple months old & rubber seals on it should be good, but a person can never be completely sure.
Anything I can do to fix what I've got? Should I slap another filter on & see if it seals to the sensor shaft better or would that be throwing money away?
