Dukeboy
- 0
- 6
- Palmyra Pa.
My turn signals work fine with incandescents, I purchased LED bulbs for any bulb that signaled. Rear lights work fine. When I replace the front bulbs with LED's the side marker/signal lights wouldn't work at all. So I put the filament bulbs back in the side marker/signal lights. Then the lights for each side would work flashing together. However when I turn on the headlamps they would stop working and the dash indicator lights would illuminate as well. Is this because a diode will only flow one direction and the circuit requires it to go the other way to alternate the front signal and side marker/signals when the headlights are on? If so can I rewire the side marker/signal lamps to make them work another way? If all else fails the filaments will go back in but I'd like to find a another solution.
Thanks in advance
Thanks in advance
