I recently installed 27w LED Off-road Lights to help with plowing. Got the lights off Amazon for about $60/pair without wiring harness. Really impressed with the LED's, they are super bright, can run off 24 v, and only draw 1.8 amps per pair. Nice they can run off 24v since I'm already working the front battery pretty hard between the radio, yellow beacon light, and the plow motor. They seem very sturdy for the price with an all metal housing Since amp draw is so much lower than HID's or 100w Off-road lights, I did not choose to use a relay, just a heavy duty 10amp switch, I ran power from the 24 V source behind the batteries. I installed 2 in front and 2 in back. I ran separate switches for both. I had added a back up light previously that was wired into the reverse circuit, but having it switched separately will let me use the back lights as a work light when I'm behind the truck spreading salt or gravel.
Seems like a ton of light for the price, I'll post if I have any problems with durability. They are floodlights so better for worklights or slow driving like plowing, probably not enough reach for higher speed driving and way too bright to use on road
Here are some pics:
Standard Headlights
LED's
Here are some pics:
Standard Headlights
LED's
