2027Deuce
- 1
- 0
- Laurel, Nebraska
Search turned up nothing and TM may be incorrect or incomplete. To adjust the brakes on the 105 trailer it says to turn the adjusting bolt counter-clockwise until the wheel stops turning and then back off until the wheel turns freely. Repeat process on the lower adjusting bolt.
This worked fine on the right (passenger) side of the trailer but the bolts needed to go clockwise on the left side of the trailer to make the wheel stop turning.
My question is: Is this correct? Are there RH and LH adjustments on these brakes? I would not think so but stranger things have happened. I was hoping not to need to dig into the brakes to figure this out.
