AK_M1028
- 0
- 6
- Fairbanks, Alaska
I in the middle of installing the lift on my M1028. I got called to work so I only got the front installed so far. I'm going with the ORD shackle flip in the rear and did find that it would affect the load capacity of a M1028. The M1028 has an overload spring which contacts brackets connected to the frame when loaded heavily. Unless I relocate the brackets down lower, the overloads will be useless. I have a plan to do this because I haul 3,800# in the rear of the truck quite often. I'll take pictures of my solution in a couple of week when I get home.
