Light trouble
Diamondjim11
Sunbury,Pa
Hey, Guys,
I just changed the headlight on my 5 ton, and I didn't notice before but now when the headlights are on high beam I have the red indicator light. When I dim them the red light does not go out but glows very dimly. Is this normal? I didn't notice it before. And if not what is going on. I tried switching the end prong wires on the light, but that didn't help. :confused: Any suggestions? Thanks
Jim
OSO
Arlington,Wa
Sounds like a bad ground to the lights, to keep the high beam light on. Use an ohm meter to check the grounding of the headlights:idea::idea::idea: OSO
doghead
4 Star General /Moderator
1,176
NY
Does it glow, with the gauge panel lights off?
Diamondjim11
Sunbury,Pa
It glows as long as the headlights are on. I believe it will stay on when the panel lamps are lit also. It just didn't seem right to be on all the time.
doghead
1,176
NY
The reason I asked that was, there is some "residual/stray" light from the two gauge lights, that does make the highbeam indicator glow slightly.
Tonight, turn off your gauge panel lights and see if the highbeam indicator is still glowing with your lowbeams on.
Diamondjim11
Sunbury,Pa
I can tell you with the panel lights off,and the headlights on lowbeam the indicator glows dimly. On highbeams it is very bright. Once they are dimmed it is dim but very apparent at night.
doghead
1,176
NY
Well, two ways to figure this out for sure.
Remove the highbeam indicator lens cover(just unscrews), and look at the indicator bulb. Is it lit?
Or, remove the bulb and test for voltage.
If either test shows the light is actually lit, while on lowbeam, then you have a wiring problem.
I don't think you have any problem, from what you describe.
