Overdrive
- 95
- 28
- Wentzville, Missouri
OK, I have been piddling around with not fixing my brake lights that stopped working when I picked up an M1082 from Ft. Leonard Wood for a friend. So, I am determined to troubleshoot and fix the problem and will keep updating this thread with the adventure...
1. Issue - brake lights were working then while on a trip at some point stopped working.
2. Status of other lights - All other service drive lights work, headlights, turn signals, running lights, and hazards. Need to verify blackout drive lights next and see if the BO brake lights also are not working (needed for section of TM troubleshooting). During the trip in question trailer lights were not functioning either. Missing relay so need to plug in a 24V relay and test to see if trailer lights are still not working.
3. TM used and page numbers - Troubleshooting electrical system in TM 9-2320-365-20-1. Going to look at two different fault numbers e59 One or Both Stoplights Do No Illuminate (2-710) and e61 Stoplights and BO Stoplights do not operate (2-740).
Some things already done:
Tips:
OK, this is where I am so far. As I troubleshoot and figure things out I will keep updating this post. I am switching to following the TM so we will see where that takes me.
Hope this helps someone.
OD
- Verified bulbs are good.
- I have a multi-meter but no STE/ICE test box
- Brake light switch no power - turned on stop light on light switch then checked for voltage at one of the two terminals on brake switch - no power - have to go redo this test as it looks like there are two switches off the brake pedal valve.
- I checked a couple of the relays. One had no power to it at all. I need to go back and document which relay and its label on the PDP chart
Tips:
- Remember, the main light switch on the dash ALWAYS has power to it even if the master power switch is off
OD
