Overdrive
- 95
- 28
- Wentzville, Missouri
Quick little write up... Had a couple lockable fuel can holders collecting dust so I found a spot behind the rear wheels and fender to mount them securely.
Seemed like a good sturdy spot on top of those big steel brackets. Also tied them in at the top with some thick L brackets under the bed so they would be nice and secure. Had to remove the J bolt for the mud flaps but I can add it back on the other side of the can mount to retain that function.
They are completely protected by the fenders so no rocks kicked up by the tires should hit them.
OD
OD
