- 10,365
- 6,342
- 113
- Camp Wood/LC, TX
I had the misfortune today to drive the LMTV on an area of ground I thought would be just fine to drive on. The pictures tell the story. The unloaded but heavy LMTV (L, really??) pushed the MVTs 12" or more into the wet ground. I had the Allison in "mode" and as the sinking in got worse I gave more and more throttle until at the end it was WOT, inching forward. As you can see the MVTs packed up. The ground is typical gumbo. I am not at all happy with the way the FMTVs apply power in heavy pulling situations. With an old gen deuce, you can gear down and get on the throttle and tires will spin on concrete, mud, whatever. With the FMTVs, the gearing is so high that from a standstill, the torque converter just absorbs all the power, and the engine is stuck under 1000 rpms, and it just bogs. I guess the moral of the story is be very very careful what your drive your FMTV into.
