lmtv will not come out of neutral
NDT
6,530
Camp Wood/LC, TX
No codes means keypad is shot. Send it to transmissioninstruments.com for free verification.
mogger7
gloucester Va
1994 don't have a clue what a wtec is nothing on display im in the process of hacing it shipped from texas to va. but can not find some one to bring it here
NDT
6,530
Camp Wood/LC, TX
Oh, you are providing confusing information. By saying "no codes" that tells us you know how to pull the codes and the display is working. But now you say "nothing on display". That could be any one of 100 things wrong to cause that.
As far as hauling your truck, you want Joey at United States of Freight to set that up for you. That way you have zero headache about it.
mogger7
gloucester Va
no codes is what prior owner is telling me im 1500 miles away he said nothing apears on window when u press the up and down arrow at the same time meaning no codes and nothing on desplat maybe i used wrong terminalogy sorry the owner (prior) was going to back it up on a lowboy trailer since it will not move on its own but don't know how fat it can be towed down the street to a parking lot where it can be loaded the driver said he was not going to back his rig down the side street 500 plus feet . so i own this truck but don't know if i will ever get to see it
NDT
6,530
Camp Wood/LC, TX
No problem towing it 500 feet. Seller needs to do whatever he can to accommodate an 18 wheeler. Driver will not want to back up that far or operate in a residential area.
Nothing on display as I said can be many many problems. Get it home as Suprman advised and then you can start diagnostics being guided by the technical manual.
wheelspinner
1,521
North Carolina - FINALLY !
I had this problem with mine. The plug in the back of the dash keypad was loose. It took like 10 minutes to check and fix it. Less time than a tow hookup would take. Seems like a worthwhile look.
Also does the truck have batteries in it or are they starting with a jump? No batteries = no 12v to trans controller.
