REDWOLF
- 0
- 0
- Risingsun Maryland
This is probably a stupid question, but how much noise should the locker in my M1009 make when I am in mud or with poor traction?
No offense but you have no idea what you are talking about.The 1009s have a limited slip differential which uses standard spider/side gear type of differential, the limited slip is handled with clutches.
The Detroit Locker on the 1 tons is a sprag clutch system which eschews with the side and spider gears to differentiate axle velocities. It can make noise when differentiating.
If the Gov Lok is making noise, you have problems.
The 1009 is not a LSD. It is a gov bomb.
A Detroit locker is locked until you turn. Then it unlocks.
It's loosely classified as a locker. Not a LSD.Go take a look at Figure 113 in the -34P and tell us what you see. The governor is an axle velocity governor. Specifically look at items 6, 8, 14 and 15. Those are the CLUTCH PACKS.
Per the Lube Order, the M1009 just uses gear oil, no additives.What fluid do you use in these gov lock rears? Regular gear oil? Is there a way to check the oil level ?
