bones1
- 4
- 18
- Southern Maryland
Challenge to Peashooter...............I know you can make them![Very Happy :-D :-D](https://www.steelsoldiers.com/images/smilies/icon_biggrin.gif)
Challenge not acceptedChallenge to Peashooter...............I know you can make them![]()
here is a good post that compares the 2 (Ouverson vs AVM): http://www.steelsoldiers.com/showth...a-closer-look!&p=221043&viewfull=1#post221043I,m about to pull the trigger on a set for my A3. Any big difference/performance between Ouverson ans AVM?
JC
http://www.steelsoldiers.com/showthread.php?20213-Ouversons-vs-AVMI,m about to pull the trigger on a set for my A3. Any big difference/performance between Ouverson ans AVM?
JC
I agree. You can get them from Scott (Tie6044) as he mentioned in post 11. He is a great guy to deal with and good friends with Randy Ouverson so its a win all the way around. I think the Ouversons must be the only deuce lockouts that actually use a bearing rather than a bushing.... apparently bearings arent needed, but if I'd prefer a shielded & sealed bearing over a bushing anyday (selectro's have bushings also)Boy, a lot of info, good tech advice, and a little person preferences. I like American Made, less plastic parts. Thanks for the links
JC
Short answer: middle axle.Okay, anyone know what axle to use to run a lockout on a rear hub?
Yep, 1 lockout hub and 1 axle shaft with splines on both ends. This is the one I used and I got it from TIE6044 (Scott). http://www.ouversonusa.com/rockwell_16spline.phpOkay, anyone know what axle to use to run a lockout on a rear hub?
Very nice, would that shaft be comopatable with the avm's?Yep, 1 lockout hub and 1 axle shaft with splines on both ends. This is the one I used and I got it from TIE6044 (Scott). http://www.ouversonusa.com/rockwell_16spline.php
(Sorry, just realized I missread your question, I ended up putting the lockout on the front driverside tandem axle which would be the wheel right behind the drivers seat)
Long answer: Like every other question, the answer is already out there: http://www.steelsoldiers.com/showthread.php?38371-deuce-transmission-disaster-(pics)
Yes, it would work for any of them. It basically makes the rear axle into what a front axle would be as far as the lockouts are concerned. So any lockout that works on the front hub of a deuce will also work on a rear hub if it has this double splined shaft. I'm not sure who else besides Ouverson makes the double splined axles for the rockwells?Very nice, would that shaft be comopatable with the avm's?
yes i was. i found the info i needed. thanks everyone.Clinto, I think he meant what axle shaft to use. Just a guess. I was wondering the same.
