Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
So, under the hood, with the exception of the starter, it is all 12 volts? Should I run into a problem with the 24 volt heated racor filter I just got? or could I tie that in to the 24?
Also, the outlets int he cab say 24 volts,..hope that is right as I just ordered a 24 volt dc to 120 ac converter.
yeah there are 24 volt stuff in the truck and your better off with the 24v to 120. you can tie in to 24v off the junction block on the fire wall on the right side.
But you do have 12v there too, there not a full 24v truck. All the driving lights and dash lights, heater blower ect are 12v. You can tap in to the in the fuse block.. there should also be a low amp (30 or less) 24v fuse in the fuse block also. There all marked.
