jdeoliveira74
- 2
- 0
- wilmington nc
which spin on is the best.. looking for on with heater and primer maybe even water in fuel so idiot lights still work !
hey when you did yours did you have to re run fuel lines and set it up on the suction side of the fuel pump instead of pressure side?Check out Racor there probaly the most expensive but they have the primer, heater,water in fuel if you want it. i wanted to get the the R445T 10 micron for my cucv but no issues yet . I run racor on my boat.
Where did you order it from?Another project complete. Big difference in power and engine runs smoother fixed my issue!
WVO is very popular with older Mercedes because of the design of the fuel injection system. I don't plan on running WVO in my Mercedes or my CUCV, it is too much trouble to collect it and clean it up. I do however plan on running 50/50 Diesel/WMO at least during the warmer months. I have a pretty good supply of oil in my junk cars, plus I still service some customers cars too. I like the idea of free fuel. I probably will get a filter setup to use 2 micron filters at that time, or just filter it before dumping it in the tank.they guy I purchased it from does alot with wvo and Mercedes
