Glad to hear it's running. Any transmission issues like the ad posting said? Does it steer any better than mine?
I sure like the color of yours a whole lot better than the color of mine. Looks like your tires were better too.
I haven't detected any issues yet(just got it running today),It does seem to steer easier than the Morganton 561.
The engine was frozen(rust on the rings) as well as the clutch stuck to the flywheel on this Goat,some fogged in penetrating oil in the blower,and a little easing it back and forth in 6 HI,4th gear got the engine to loosten up as well as the clutch.
The injectors were another issue,#1 and #2 were OK(plungers and control rods moved) but #3 was stuck fast(plunger stuck down as well as the control rod stuck in the fuel off position).
2 days with the injector soaking in penetrating oil got both to loosten up,and I installed it this evening,checked the height and rack settings,and it fired up within 10 seconds cranking.
The tires on it are not as weather checked,but have less than 40% tread remaining.
It has a bit more body dings and dents,and will never be swimmable again,the tailgate is trashed,it was in the bed with about 500 lbs of scrap steel and wood.
