Lot of Jeep questions
citizensoldier
17
Northern Michigan. Smelt City
A friend on here has a WWII jeep. Here is what the main data plate says from what I can make out.
It is a Ford data plate and not brass
It has these numbers stamped in it.
158878
11-5 48
It has another stamped alluminum plate on the middle of the dash
It is stamped
5536949
20-10-48
The frame is a MB 340380
The motor MB 155516
The head is a Ford script 6050
So can anyone enlighten me on all the meanings.. Does this mean it was put together from three jeep in 1948? they didnt make tubs in 1948 did they?
Tackettr
Edmond/OK
I would check on www.g503.com Don't get me wrong, SS is a great website but G503 seem to be geared more to WWII Jeeps. Kinda sounds like an early production Ford GPW on An MB Frame, but then again it could be tossed salad. I know 48 isn't a production year for the GPW. Good Luck.:-D
citizensoldier
17
He tried posting on that site and has had no responses. Was it common practice to throw a jeep together after the war and then just tag it the year they did this? I will take my camera over and get some pictures to help with this. So I am trying the SS guys..lol..:-D
txdodge43man
Magnolia, texas
From what I know about WWII jeeps a lot of jeeps after the war were rebuilt and a lot of times they would take three or more jeeps to make one. What you have there is a jeep that went throught depot rebuild in 1948. it is comon to see a ford tub on willis frame and motor. Im not sure when production of the WWII jeep stop but I belive 1945 was the last year.
ida34
33
Dexter, MI
The did have mix master jeeps with different stuff. I do know that some jeeps ended up registered by the year they were surplused and not the actual year of manufacturer. And while I am at it, why are you not posting pictures?
Todd Haley
Crittenden, Ky.
looks like the frame was made around the end of may,the first part of june 1944. the alum. tag in the center of the dash should be a rebuild tag,possibly reconditioned in Ger. or Japan. The info on the Ford tag does not sound factory,maybe restamped at rebuild depot?
At a rebuild depot they would have stripped the entire vehicle, all sevicable parts were sorted and the a frame would have been fitted with the apropriate parts so yes, a jeep could have been reassembled from three,four,or many more to make a complete vehicle:-D
Please post some pics of all tags when your Batteries warm up!
mikes47jeep
13
North East PA
with the ford data plates on the dash and the ford engine I'm betting its a 1943, it's very easy to misread the worn data tag as 1946, 1948, or 1949
ford quit production in 45 so my offical estimation is 1943
more photos of the whole jeep would help
Mike
mikes47jeep
13
North East PA
The GPW was made from 1942–1945,
It’s defiantly a GPW tub because it had the round indentation for the tool box latches, willys had a square indentation
And it’s defiantly a GPW frame because the front cross member under the radiator is a channel, on the willys they were pipe
It looks like you have 4 good combat rims on it too
Keep us posted,
Mike
phantomjeep
NW Lower Michigan
more pic's
here are more pic's from tags and round MB cross member ,the angle iron is from the capstan winch . transfer case is F , tire mount is F , black-out lights F .
