Sorry new here. I just purchased an Libby mep804a from auction. It shows up it quits raining and i get to play with it. I found a soggy check out sheet inside. It states missing a few parts rust in places Low power light on and has 2 bad Ground circuit interrupters. When i put batteries on it i fired it up it showed 400v a/c on gauge. Any time i have started it after says 400v while cranking but after that it shows like 25v while running and 400v while cranking only. Currently i am checking and fixing rat chewed wires but so far none of them seem to be no more then insulation chewed off. Still looking at those however. I read in other posts how to check VR and will do that soon. Yes so far all my parts say Libby on them. When i flip the A/C interrupt switch nothing visibly changes. The light does not come on nothing on gauges changes. Checking voltage and convenience plug it shows 14v AC. Flipping the battle short switch does nothing.
I have also noticed may have nothing to do with it but when i select preheat the engine cranks and runs.
I did find and download the Ts manual someone posted. Thanks for that it may help.
