M 1031 duel wheels
deank
540
Inverness, Florida
I have an M1031 with single rear wheels. This is what I found on wikipedia:
The M1031 was the chassis cab. These latter trucks were all rated for heavier 3,600 lb (1,600 kg) or 3,900 lb (1,800 kg) loads, compared to the M1008s 2,900 lb (1,300 kg) load capacity. The M1028A2 (converted M1031 or m1028a1) and m1028A3 (converted M1028 ) models had dual rear wheels.[12] Many M1028s were upgraded at the company level to M1028A2 and A3 specs—the dual wheel rear end arrangement was a result of the M1028 flipping on its side because of the high center of gravity when carrying equipment shelters.[13]
NDT
7,101
Camp Wood/LC, TX
My observations on the DRW SECM CUCV trucks, they all seem to have the transplanted M887 bodies from the M880 series Dodge trucks. I think Uncle pressed these into service as an expedient due to the SRW M1031s with the new shop bodies taking so long to hit the field.
deank
540
Inverness, Florida
I am curious. What was the difference between the m887 work box and the m1031 work box? Did the m887 have the gasoline generator? I have seen some m1031s with PTO driven gens and some with gasoline gens.
  • Like
Reactions: rtk
NDT
7,101
Camp Wood/LC, TX
All the 887 derived 1031s had the gas generator/welder. The box is similar between the 887 and the newer 1031, the newer box being set up with the PTO generator and the Miller XMT welder.
powerwagonwc12
11
College Station, TX
I would like to convert my M1008 to a dulley is there a templet or instalation information for the fenders or conversion kit instructions or a conversion kit avalible?
