Armydillo
- 0
- 0
- Boonies Texas
I have 3 spicer 3053's trannys with the 5 speed overdrive. I am finishing up a powerwagon 4bt swap where i bought the Phpneix casting sae 3 to 2 adapter for $500.. What I need to know is has anybody here ever taken the transmission bellhousing off of a 5 ton truck(which i understand is sae#2) and swaped it out with the sae#3 spicer M-35 transmission bellhhousing??
That way i could just buy the 5 ton transmission bellhousing in sae#2 seperate and then bolt it where the spicer 3053a sae#3 was at?
I have found and bolted up an aftermarket 5.9 cummins made in china flywheel and bellhsing for a fl 80 in sae#2. Anybody got just the front part of a 5 ton transmsiion for sale or has ever done this swap out with a 3053a to avoid the sae adapter? The adapter is about $500 yikes, i figure somebody would part out a 5 ton spicer tranny if this will interchange?? Thanks in advance
