63Wfirefighter
- 0
- 0
- Loving TX
Ive seen that some of the Multifuel engines can be fitted with a spin on oil filter kit and was curious if there is a kit for the M-52A2 engine and if there is where can I get one?
The original filter housings are held on with a bolt, you remove the housing, discard the element inside, clean the housing and install a new element. Spin-ons are faster, more convenient, less messy and also have the advantage of an anti-drainback valve in them to help speed oil pressure upon start up.what is the original method of putting on a filter if the spin on is the upgrade?
