- 9,576
- 211
- 63
- Dickson,TN
Well today I got all the brake lines and valves repaired, and energized the air system for the first time. Found out that at least on the axles I checked, brakes and linkages are frozen. It appears that this trailer has sat for a long time, and any grease on it has turned as hard as a rock. Pulled one hub off, cleaned everything up, and put it back together. The one I took apart now works fine, only 19 more to go.
Earlier this week, I got the last of the hyd lines on and did a hyd function test. The steering wedge was frozen, but with the use of a porta-power I was able to get it freed up. Now all the hyd seems to be working like it should.
