- 258
- 274
- 63
- Grove, Oklahoma
The heater/blower motor on my M1008 works on occasion. I would like it to work when I need it. This is probably a typical Chevy/GMC problem and not specifically a CUCV issue. The switch feels "Good" (not sloppy or loose), the vent controls (off/defrost/heat) seem to have the right amount of friction in movement and the cool - heat lever at the bottom of the cluster also seems to have the correct amount of friction. What do you think? What can I check? Will my voltage meter be helpful?
If this is a redundant post, I apologize. I don't yet have the skills to adequately search the threads...
