I would pull your drums off, clean everything up on your braking components, check the proper fit of your brake shoes, and adjust the brake shoes the proper distance from your drums when re installing. It could be your shoes were not adjusting properly as they wear. For your safety and the safety of others, I would not drive the vehicle until it is working properly. You lose all your stopping power when your rear wheel locks up.@Keith_J is onto something I would also check your soft lines. If they are old and worn they can start to collapse on themselves restricting fluid travel and causing issues. After that a good brake bleed at all four corners would also be advised.
Excellent advice. And if the brakes have oil on them they are junk. Change them and correct the oil leak. Oil leaking has always been the issue with the rear drum brakes on the M1008-M1031. Do it right and use new axle flange seals also.I would pull your drums off, clean everything up on your braking components, check the proper fit of your brake shoes, and adjust the brake shoes the proper distance from your drums when re installing. It could be your shoes were not adjusting properly as they wear. For your safety and the safety of others, I would not drive the vehicle until it is working properly. You lose all your stopping power when your rear wheel locks up.
With the additional information I am going to guess a wheel cylinder or a rusted thru brake line. If it is rusted thru start at the front and replace all of it. It is easier now than waiting for the next blow out.Thanks for the replies, it seems the front half of the master cylinder had lost most of its fluid. Topped it up and it seems fine, but where did it go, no obvious leak. Was at an event at the time, so will check properly this weekend.
Also look under the driver side floor mat if you have them, a leaky master cylinder will sometimes leak inside the cab.With the additional information I am going to guess a wheel cylinder or a rusted thru brake line. If it is rusted thru start at the front and replace all of it. It is easier now than waiting for the next blow out.
You might need a new gasket under your master cylinder cap.Thanks for the replies. Topped it up , used the truck, braked hard a few times, checked everything suggested, nothing, totally dry everywhere & brakes working fine ! Only possible leak was a bit wet at front of master cylinder cover .
