M1008 seat belt floor mount base bolt size ???
MAZ537
23
EU
Can anyone please share the specs of the bolts that secures the seat belt mount to the floor under the seat ?
Both are missing on my truck !
Socket size , length and thread it would be awesome !!!
Happy new year guys !
porkysplace
1,493
mid- michigan
Not finding anything through parttarget.com ( usually a good source ).
All the GM searches come up as a obsolete part.
I did find this in a GM parts catalog [ 4 16 714 BOLT HEX 12X1 75X35 CAD ]
doghead
4 Star General /Moderator
1,179
NY
From the info PP posted,
12 mm X 1.75 thread pitch, X 35 mm length
It should be readily available in Europe.
DREDnot
443
Phoenix, AZ
I just happened to have mine out.
It is indeed a 12x1.75x35mm with a hex head 22mm(7/8")
They are, however, slightly swaged into a triangular cross section that acts to lock them in place.
It may well be a common "seat belt bolt"
You might want to use locktite on any non-swaged replacements
MAZ537
23
EU
Thank you all for your great help !!! [thumbzup]
I hope to find them available here as they are not a hard to find size...One more question : are 10.9 grade bolts suitable ?Also seems too much to ask someone to ship you two bolts overseas...
Happy new year !!!
porkysplace
1,493
mid- michigan
10.9 should be fine . It seems while I was searching it came up as grade 12. As was mentioned some blue locktite might
not be a bad idea. I try to stay away from the red locktite on anything that may need to come apart again , unless it is a easy location to apply heat.
