btrapr
- 0
- 6
- Monroe, NC
I have been reading here and there trying to figure out a safe RPM range for sustained runs on the Interstate. I am trying to figure out what combination of parts I need to make this drivable on the Interstate since it is the only truck I own at the moment!
The RPM calculators are showing around 2260 RPM's with 30.5" tires, 4.56, auto trans A 45MPH________I believe that is the max speed rating the military gave them.
If I add a 700r4 and leave my gears with the 30.5-31" stock military tires it looks like I will be around 2286 RPM's at 65mph...WHICH is within the above listed range! I do not really want to do a lift kit and large tires.
WOULD this be a safe range for like a 2-3 hour drive? OR would I be better off switching to 4.10's OR 3.73 (which adds a another part list)? I am trying to keep the cost to a minimum! Transmission swap vs. gear/trans swap!
Is anyone running the 4.56's and a 700r4 on pretty much the stock drive train?
thanks in advance!
thanks in advance!
