Stratoghost
- 0
- 0
- Belpre, Ohio
When my truck warms up on a very cold morning, like we've been having the past week, a sheet of fog starts coming out from the front of the dashboard next to the windshield. It doesn't smell like radiator fluid and the radiator fluid level is the same as it has been. It doesn't smell like anything. It is very slightly greasy, but easily wipes up off of the windshield. The problem is the volume of fog. I don't have far to drive to work, so I'm lucky in that respect. When I get to work, my window is rolled down and fog is pouring out. It only does this in the mornings. When it gets above freezing, my windows get fogged up. This has been occurring for only this past week.
Here are the things that happened a week ago that could be responsible:
My fuel system developed a leak and has been sucking air. I have been having to bleed the system every morning before I start the truck. I have a switch operated inline electric fuel pump installed as well as a spin on fuel filter. My mechanical fuel pump seems to be dying as it loses power going up hill or accelerating to highway speeds. I have been using the electric fuel pump as an emergency assist. I am replacing all the fuel line in the engine compartment and installing an Airtex E3158 this weekend.
I had a new windshield installed a month ago. Everything seemed fine until my last trip to Pittsburgh. It is a 3 hour trip for me and it rained the entire time up and especially back on Sunday. As I was getting near home, the rain started to come in from the top of the windshield. I had it repaired on Tuesday and it hasn't rained since Monday.
On my trip up to Pittsburgh, my Low Coolant Level light came on. I know that the wiring has shorted out in the past, I had put electrical tape on the spot I found and thought that it might have been a reoccurring problem. A few minutes later, the light started blinking. It started out slow and started getting faster. I pulled off at a rest stop and let it cool down. While I waited, I filled the reservoir with water. It was empty. I don't know if water got in the lines or what as the short didn't go away. The radiator was full. The next day, the light was out and stayed out. I bought a new thermostat just in case.
I tried searching the CUCV forum but didn't some up with anything. I think the new search system is a little off, or I just can't find the right terms to use. I know you guys have been great with suggestions and solutions in the past. Thanks in advance.
