M1009 Exposed fiberglass hard-top
kallisti5
23
Texas
So, I'm noticing the exposed fiberglass on my M1009 is suddenly rapidly accelerating.
I'm currently experimenting using bondo-glass on the exposed areas to try and seal them,
but so far the results haven't been great. (and it's going to take a lot of bondo)
Any ideas?
I wanted to keep the M1009 stock since it's kind of a farm / utility truck at the moment, but I think a
replacement hardtop or maybe a soft-top might be in its future :-|
cucvrus
10,399
Jonestown Pennsylvania
Sand it and lay a light layer of finish filler on it. Sand it smooth and repaint it. Or crush it burn it and replace it. I have a few but I am in Pennsylvania.
corvette9
new haven ct
Simple polyester resin. You can buy it at any automotive store. mix it and apply with a brush. It will soak into the dried out glass and once hard can be sanded then you can repaint the top. You can also buy an additive to put in the paint to duplicate the texture.
nyoffroad
687
Rochester NY
Easier than bondo or mat and resin, go to an auto paint supplier and get some Gel coat. Gel coat is what is applied to the mold before the fiberglass, gel coat is sandable and paintable and is available in some colors or even tintable. Its high build and easy to use and requires little surface prep. If you have trouble finding it at auto shop check boat dealers but anything boat related is 20-50% higher.:)
edpdx
75
Oregon
When I painted my entire '09 at the Community College Paint shop my instructor told me to use the high-build Polyurethane primer on my fiberglass top- which was starting to show 'glass'. "Lay it on real heavy- three or four coats."
After that I laid the Gillespie 383 on thinned with Xylene. Dried as I hoped, and the finish is great after 5 years now.
