- 66
- 1
- 8
- south east louisiana
Just picked up the truck today and noticed a leak coming from under the dash, along the right kick panel when it rained.
What gasket would need replacement?
what about the air vent gasket?The windshield gasket is probably bad and you might have rust.
+1 on the nuts diagnosis. If there is a leak in the windshield gasket, it will most likely be rotting the window frame (rust). Rain will get in and present itself as it drips from inside the front pillar. Get in there with a headlamp and look for water residue. The real giveaway is if there is a crack in the window at the edge on the side where it leaks. The weakening frame no longer supports the glass in that spot and it will eventually crack.The windshield gasket is probably bad and you might have rust.
I'll second this, check cowl area (below windshield, behind hood).what about the air vent gasket?
