kipman
- 15
- 38
- Lancaster Ohio
I have a problem, replaced the IP and injectors last night, got it running, has a hesitation off idle, stalls after bringing the rpms up, do not believe there is any air problems, old pump was set 3/16 to the right on the timeing marks, I set this one dead on, could the timeing cause this problem, it will start right back up after it stalls, seems ok at highway speeds. the problem seems to be at idle.
